- $2.00
mBot Li-polymer battery is suitable for the mBot(blue & pink) of Makeblock. It takes only 1 hour to fully charge the battery and the battery can last up to 2-5 hours in the offline mode.
Charging method: Charging via mbot's USB cable. The battery does not include a charger.
Protective cases: prevent overcharge/overdischarge/short circuit/overcurrent
Type: Li-polymer battery/Rechargeable battery
Charging method: Connect to mCore via USB
Capacity: 1800mAh
Nominal voltage: 3.7V
Charge cutoff voltage: 4.2V
Discharge cutoff voltage: 2.75V
Charging current: ≤1.0C
Discharge current: ≤1.0C
Weight: 33g Dimension: 1 * 3.5 * 5cm
WHAT ARE YOU LOOKING FOR?
No Results Related
Thanks for subscribing!
Thanks for contacting us. We'll get back to you as soon as possible.
