All-In-One Education Solution
Get your all-in-one education solution with complementary lesson plans, materials, software, and communities. Build your class with lasers and help students reach their potential for future.
Laser Engraver
Desktop 55W CO2 laser engraver enhance your classroom with effiency and high safety.
Free Software
Free Software is easy to use on PC, iPad, or mobile. Step into XCS Cloud storage systems that are accessible anytime and anywhere.
Standard-aligned Curriculum
Seamlessly integrate our hands-on lessons into your existing curriculum to enhance classroom efficiency and learner engagement.
Inspiring Projects
Easy and fast to find inspiration in 1000+ regularly-updated real-world projects that are simple, easy to understand.
Well-selected Material Pack
Well-selected materials packs aim to streamline lesson planning efficiency and save time with curated supplies for educators.
Powerful Laser Engraver for Efficient Classroom
Enriching Subjects, Empowering Minds
Bridging theory and practice for students, making learning intuitive and fun
Use xTool P2 educational laser cutter to craft prototypes, visual aids and interactive tools for innovative teaching and learning.
See xTool P2 in the Classroom
All-rounded protection for future STEM leaders
Fire Safety
P2 is compatible with xTool fire safety set. It can detect the flame, trigger the alarm and extinguish the fire to ensure a safe workspace.
Emergency Stop Button
xTool P2 has a built-in emergency stop button for a quick shutdown in case of emergency.
Enclosed Design
With the enclosed design and the light-filtering lid, there is no need to worry about light or smoke leakage.
Automatic Lock
The lid of the machine will be automatically locked while processing. This feature makes it an extremely safe machine, especially for families with kids or pets.
Multiple-Warning System
xTool has a multiple-warning system that guarantees the proper functioning of the machine by alerting to the over-temperature of the motherboard and cooling system, lack of cooling water, and more.
Excellent Smoke Exhaust System
We know indoor smoke exhaust poses challenges, hence a smoke purifier is here for you to create a cleaner environment for all young minds. Its advanced filtration system can effectively eliminate 99.7% of particles.
Dual 16MP Camera for Precision and Easy Use
xTool P2 is equipped with dual 16MP smart cameras. With the high-precision real-time preview and autofocus function, see expected engraving results and engraving process without peeking inside the machine.
Efficient Classroom Cutting from Every Aspect
Superb Cutting Ability
xTool P2 can cut 18mm black walnut and 20mm acrylic in one pass. Getting students what they want at one click, and keeping them engaged has never been easier.
55
w
Laser power
mm
Acrylic in one pass
Higher Working Speed
xTool P2 can cut 3mm basswood at the speed of 35mm/s , which is 6 times faster than a 20W diode laser. Even with only one P2, every student can enjoy laser cutting in the classroom.
600
mm/s
Max engraving speed
Endless Possibilities with Hundreds of Materials
*xTool P2 (CO2 laser) can engrave on coated metal, anodized aluminum alloy, and anodized titanium steel. For stainless steel, you need to spray coating on it before marking it.
Create Whatever They Want
Promote open-ended learning experiences
Laser on the Curve Surface
xTool P2 can automatically construct 3D models of curved objects and automatically adjust focal length during processing, making the engraving result as perfect as it does on flat surfaces.
Laser on the Thicker Objects
xTool P2 supports engraving objects with a maximum height of 2.7 inches. By adding the riser base (included in Premier Bundle), it can even engrave objects up to 8.4 inches.
Classroom-ready Software for Free
Create with Any Devices
From editing to processing, experience a seamless, efficient workflow with xTool Creative Space (XCS) whether you and your students are using a PC, iPad, or mobile.
Wi-Fi Connection
USB Connection
Ethernet
Create with Ease, Profession and Order
Master in 3 Easy Steps
One-click operations: image import, outline adding, engraving & cutting settings, material settings.
Save time, Use AI Design
Instantly prepare for your classroom by typing your words and witnessing as AI effortlessly creates the visual style you envision, utilizing AI design.
Cloud-based Storage
All files can be stored in the cloud so that you can log in and save all classroom content there.
Upgrade Your Laser Classroom Solutions
The Premium Bundle includes the necessary accessories to enhance the classroom experience
Automatic passthrough
Assembled with the Automatic Conveyor Feeder, xTool P2 provides the automatic passthrough for precision and convenience when engraving and cutting extra-large materials. Perfectly for time-saving when every students's design has been created in the same file.
Set Up an Engaging Classroom Now
xTool P2 Educational Premier Bundle
All-in-One Education Solution Learning Resources
· 36 standard-aligned curriculum
· 300+ Inspiring projects
· Easy-to-follow tutorials
Powerful Laser Engraver with Fast Speed
· Power: Desktop 55W CO2 laser for all-colors acrylic
· Speed: 600m/s work speed, enough for students to experience in 45-min sessions
Learn More >
Thickest Cut,Fastest Engrave
P2: 55W CO2 power
F1: 4000 mm/s speed
3 Lasers to Engrave Everything
P2: CO2 laser for all-colors acrylic
F1: 10W diode & 2W infrared laser for wood, all-metals,etc.
Studio Mass Produce+ Onsite Customization
P2: 55W CO2 power
F1: 4000 mm/s speed
P2: CO2 laser for all-colors acrylic F1: 10W diode & 2W infrared laser for wood, all-metals,etc.
P2: 26*14 inches workspace
F1: 4.6kg easy to carry around
Learn More >
xTool P2+F1 Educational Productive Duo
Let's Compare
Laser Mastery from Day One
Easily
drag the drawings to the right place
Easily drag the drawings to the right place
xTool P2 is equipped with dual 16MP smart cameras. With the high-precision real-time preview and auto focus function, see expected engraving results and engraving process without peeking inside the machine.
Automatically
curved surface engraving
Automatically curved surface engraving
Intelligently
batch engraving
Intelligently batch engraving
xTool P2 can intelligently recognize shapes through the camera, and fill patterns on multiple objects and engrave on them in one batch.
Let's Compare!
xTool P2 Basic Educational Bundle
xTool P2 Premier Educational Bundle
Intro
The classic educational solution to help students master comprehensive laser cutting skills.
The latest educational solution to help students master more advanced laser cutting skills. More materials, more creative fun.
Machine
xTool P2 (Class 1)
xTool P2 (Class 4)
Accessory
Smoke Purifier: Efficient Smoke Purification Allows You to Enjoy a Quite, Safe and Clean Classroom Environment
EnvironmentRiser Base: Significant Upgrade on Engraving Thickness.
Automatic Conveyor Feeder: Engrave anything up to 3m long in size, and no interruptions in your classroom.
Materials
Basswood*18
Plywood*28, Leather*2,Felt*16, Acrylic*7, Rainbow Silicone Watch Band*4, Wooden Napkin Holder*2, Wooden Lamp Base*1, Metal Name Card*20
Lessons
36
36
*Opt for the Basic Bundle featuring a xTool P2 Class 1 or upgrade to the Premier Bundle with Class 4 model. Note that the Class 1 machine doesn't support compatibility with Automatic Conveyor Feeder.
Unboxing & Review
Product Specifications
Product Information
Rated Power: 55W(CO₂ Glass Laser Tube)
Package Size: 44.4"×28.6"×13.6" (1122×727×346mm)
Product Size: 39.4"×25.1"×10.6" (1000×639×268mm)
Product Weight: 45KG
Max. Engraving Speed: 600mm/s
Processing Precision: 0.01mm
Z-axis Movement: 3" (75mm)
Lifespan: 6000~8000h
Safety Guard: Class IV (FDA Certified)
Laser Spot: 0.15×0.2mm
Work Area
Bed Size: 26.7''×14.1''(680*360mm)
Processing Area: 23.6''×12.1''(600*308mm)
Max. Workpiece Height: With tray 2.5"(64mm), Without tray 2.7"(71mm), With riser base 8.5"(215mm)
Rotary engraving diameter: With riser base 0-180mm, Without riser base 3-50mm
AI Camera Information
Camera: Panoramic camera + close-range camera
Number of Pixels (Effective): 16MP×2
Vision Precision: 0.3mmImage
Resolution: 1000DPIFocus
Mode: Autofocus
Image Resolution: 1000DPI
Focus Mode: Autofocus
Build-in Accessories
Water-cooling System Capacity: 1.4L(0.37gal)
Air Assist (adjustable): 15-150Kpa
Exhaust Fan: 145CFM
Exhaust Fan: 145CFM
Software and Connection
Operating Systems: Windows / macOS / iPadOSControl
Software: xTool Creative Space / LightBurn
Supported File Type: SVG, DXF, JPG, JPEG, PNG,
BMPConnection / Transmission: Wi-Fi, USB, Ethernet
Control Software: xTool Creative Space / LightBurn
Supported File Type: SVG, DXF, JPG, JPEG, PNG, BMP
